Suggestions for a RELIABLE external CD drive
  • FyrFytr
    • Jun 2016
    A few years ago, I ponied up a decent chunk of change for a Samsung external CD re-writable drive w/ Lightscribe capabilities. I've never gotten around to using the Lightscribe feature, as it was put to death shortly after I purchased the drive. Thanks HP for killing something else in which I invested! Of course, this was right after I bought a crap ton of Lightscribe discs. I should have learned my lesson about HP when it killed Palm and WebOS. SCREW YOU, HP!
    Anyway...sorry for the tangent.
    Now that I'm actually using this external drive to rip discs w/ dBpoweramp's CD Ripper, the USB device regularly ejects and becomes unrecognizable from my laptop. Often, I can not get it to be recognized when I atempt to reconect it. A message of "USB not recognized" and somethng about the device malfunctioning and Windows not recognizing it (Windows 10) pops up when I plug in either of the USB connections. Sometimes it happens the first 6-10 times that I plug in the drive. Sometimes it happens between discs being ripped.
    1) Any suggestions?
    I firmly believe that this IS NOT an issue with dBpoweramp, but instead either with my OS, or the Samsung external drive.
    2) Any recommendations for a SOLID, reliable, accurate external drive to finish reliably riopping my CD collection?
    I want to get a Blu-Ray burner at some point, but I'm wiling to buy two separate devices if someone has a strong recommendation for a CD ripper. I'm really tiring of fighting with this damn Samsung drive.
  • monsterjazzlick
    • 1764
    Re: Suggestions for a RELIABLE external CD drive
    Hi Fyrfytr,
    I have had endless issues with SEAGATE drives.
    I bought a Western Digital MAINS POWERED 1TB external drive last year. It cost about 90GBP from PC World.
    For the task of storing my FLACS, I bought a Dell USB POWERED 1TB external drive this year. It cost about 60GBP from PC World.
    Paul
      • 5743
      For ripping drives, more money is not necessarily better. Best to have several drives that can work. Some problem CDs rip better with some drives than others. I have several cheap drives and some old ones I got from free from discarded PCs. A couple of years ago I bought this USB container (for inserting almost any full size drive) and this drive. I'm sure any number of drives in this container can work well. This all works very well for the last few years connected via USB to my laptop.
      • Oggy
        • 697
        https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
        Totally agree with garym, that using an internal full size drive externally, via a USB adaptor, gets you Adar more robust, quicker, drive. The Lite-On, models, are good drives.
        There is a Pioneer USB Blu-ray drive available, but it is a lot of money, to hammer, ripping CDs.
        • FyrFytr
          • Jun 2016
          Hi Fyrfytr,
          Paul
          Thank you. Fortunately, I have a Synology NAS and multiple external drives for my data storage purposes. What I need is a reliable external CD/DVD/Blu-ray drive for ripping and burning discs.
          • FyrFytr
            • Jun 2016
            Oggy, garym, thank you for your input and suggestions.
            I will begin exploring the route that you posted, garym.
              • 4015
              1) Any suggestions?
              Check whether you have the latest firmware on the drive.
              • jultsu
                • Mar 2016
                • 58
                And you want to hook it up to USB only, or is firewire a possibility?
                • Oggy
                  • 697
                  Windows 10 can be rather temperamental, with USB drives, before giving up with the Samsung, this is some advice that was posted, by Microsoft, regarding the use of, an external USB drive, with Win 10.
                  Right-click the Start button > Command Prompt (Admin)
                  Then, at the command prompt type the following ( you can copy and paste) and press "Enter":
                  reg.exe add "HKLM\System\CurrentControlSet\Services\atapi\Cont roller0" /f /v EnumDevice1 /t REG_DWORD /d 0x00000001
                  Restart the computer.
                  I've got no experience with Windows 10, but all my drives, including a Samsung slimline, external USB drive, connect first time with Windows 7.
                  • monsterjazzlick
                    • 1764
                    Hi, I am afraid I do not know about BLUE RAY. But the other guys on here are great and will be able to help! Cheers.
                    • monsterjazzlick
                      • 1764
                      Originally posted by Oggy
                      Adar
                      Adar??
                      • Oggy
                        • 697
                        Adar??
                        a far!
                        Rushing, before going to bed; and no secretary to proof read!
                        • Jailhouse
                          • Sep 2016
                          • 388
                          Regarding DVD vs Blu-ray drives, my DVD drive rips a fair bit faster than my Blu-ray. But both work well for ripping.
                          • monsterjazzlick
                            • 1764
                            a far!
                            lol
                            • corylulu
                              • Sep 2017
                              I bought the Dell DW316 for ripping DVD's, haven't had any problems with it. Pretty sure it's one of the best external dvd drives available.
