Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 56
Thread: RE: Artwork Fixes (General Qs)
  1. #16
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Re: Artwork Fixes (General Qs)
    Quote Originally Posted by garym View Post
    mystery solved regarding how foobar deals with art and multiple disks. Turns out it makes sense and is not a bug (as noted, how else could foobar know which art to show when more than one artwork is associated with an album. See this thread starting here at post 335:
    https://forum.dbpoweramp.com/showthr...l=1*post176234
    Cheers. I think last night, after spending a couple of solid hours experimenting with it all, my brain had just gotten mashed! I can see your point perfectly now, thanks. Paul.
  2. #17
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Question Re: Artwork Fixes (General Qs)
    Where, please, does 'dBba' source a CDs artwork from?
    Is it possible - in PerfectTUNES - to obtain the LOCATION of where the 'Existing Art' is being sourced from?:
    For albums containing artwork of which either PerfectTUNES suggests it fixes, or that I feel it is not suitable, I have been searching Google Images for replacements. But I am not sure if this procedure is correct because the end results have proven somewhat inadequate.
    Many thanks,
    Paul
  3. #18
    Join Date
    Nov 2007
    Location
    Florida, USA
    No clue. But if looking yourself, this is a good site.
    https://www.albumartexchange.com/
    when you find something it is just a small version. Click on it to go to the full size art.
  4. #19
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Hi Gary,
    Thanks mate.
    I was looking for the rear cover of Miles Davis's "Black Beauty". That site is useful, thanks, but it only offered the front page:
    https://www.albumartexchange.com/cov...atus=&size=any
    Now, lets say I found this on Google Images (it's not the original CD rear, but I think it looks good, and it will do). Now, the DIMENSIONS of the image are: 1500 x 1500!:
    http://www.theartsdesk.com/sites/def...re%20cover.jpg
    But my MAXIMUM ART dimensions in 'dBpa' are 1000 x 1000!
    Do you need to stick to artwork which is 1000 x 1000, or below? Or can I import an image of any size, please?
    Many thanks,
    Paul
  5. #20
    Join Date
    Nov 2007
    Location
    Florida, USA
    Import an image of any size and dbpa will automatically resize if larger than your max.
  6. #21
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Thanks Gary, As easy as that?! Would you be so kind as to remind me, please, of whether I use 'dBpa' EDIT ID TAG or PerfectTunes to replace such existing artwork? I could not find your specific post of last week. Many thanks.
  7. #22
    Join Date
    Nov 2007
    Location
    Florida, USA
    The
    Quote Originally Posted by monsterjazzlick View Post
    I use edit ID tag. But I think you can do this with perfect tunes as well.
  8. #23
    Join Date
    Jul 2017
    Location
    Wirral, UK
    The
    OK, thanks Gary. Will have a try.
    But what if the artwork you have sourced is LESS that the 1000 x 1000 dimensions, please. I mean, because the image will get stretched, does this mean the end result will look inferior? For instance, I was thinking of using this rear-cover (but it is only in the 700's-size):
    Cheers,
    Paul
  9. #24
    Join Date
    Nov 2007
    Location
    Florida, USA
    Cheers,
    Paul
    If it is smaller it will stay smaller. Won't be stretched.
  10. #25
    Join Date
    Sep 2016
    Location
    Michigan, USA
    [...] if looking yourself, this is a good site.
    I gave up on finding much decent album art online, but this site looks promising. Thanks for sharing!
  11. #26
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Hi Gary,
    So do you mean: LOAD FROM FILE:
    ... but the newly amended (uploaded) artwork does not appear in the CD (FLAC) folder?:
    ... like it does for disc-1:
    Many thanks,
    Paul
  12. #27
    Join Date
    Jul 2017
    Location
    Wirral, UK
    Gary,
    So then you will have artwork of different sizes? Will that look uncool/inconsistent, please?
    Paul
  13. #28
    Join Date
    Nov 2007
    Location
    Florida, USA
    Gary,
    Paul
    Doesn't bother me. Life's too short to sweat that sort of small thing. I try for 1000x1000but settle for whatever the best I can find. I am mostly listening. The only time I see the art is when I'm browsing to select something.
  14. #29
    Join Date
    Jul 2017
    Location
    Wirral, UK
    OK man; fair doos ...
  15. #30
    Join Date
    Jul 2017
    Location
    Wirral, UK
    ... am still struggling RE: Post *26, please. Cheers, Paul
Posting Permissions
  • You may not post replies
  • You may not edit your posts
