Set-Up for Ripping
Re: Set-Up for Ripping
Hi garym. Forgive my using this forum for a non-dbpa topic; I don't know how else to reach you. Somewhere in the posts you (I believe it was you) indicated your shared enthusiasm for the eclipse. You'll be interested in an internet site that will live-broadcast the eclipse from a high-altitude balloon showing the shadow racing across the earth: https://stream.live/eclipse. The site is up on-line now and I assume the balloon view will be recorded for later viewing as well as live.
DonComment
DonComment
Somewhere in these threads, and became of the excellent, informative answers from a number of people, are well worth reading again, I believe garym gave a naming scheme, and an explanation of how this works for single discs, multi disc sets from a single artist, and compilation box sets.
He also had a screen shot of dBpoweramp: CD Ripper Naming. Don, I know you have found this, as you have commented on some of the options.
Clicking on the dBpoweramp CD Ripper, icon, brings up the main page, and in the lower corner, you have, Profile, Rip to, Path with a Set, Naming with a set, and CD Drive.
On the Profile, you have (default), I recommend not deleting this, but [Create Profile], give it a name, I've got one named Garym! From here, have a play.
Once you have cut and pasted a naming scheme, ensuring no extra spaces are inserted, the naming scheme for each Profile, shows in the Naming box. Click Set.This brings up the box that garym posted the screen shot of - extremely helpful.
In the middle, are three tickets boxes, Current Disc Metadata, Compilation, and Multi-Disc.
In the big box underneath, in version 16, from memory 15 was slightly different, but gave the same outcome, you have in version 16:-
Album Artist\Album Title\05 Artist - Title.
This little string is so helpful. It shows that a folder with the Album Artist name is going to be created, with a sub-folder named Album Title.
If you tick the Multi-Disc box, the string looks very similar, but adds a Disc 1, into the equation. The naming scheme, the default, garym's and countless other well thought out schemes, handle multi-disc box sets, and compilations, automatically.!
I have browsed this thread as you suggested, thanks.
I was looking for this within 'dBpa' please:
PaulComment
Hi Oggy,
I found the screenshot Gary refers to, thanks.
I am guessing that if ripping a single CD, then NONE of the (3) boxes should be checked.
But what about if the album is a double-CD, please?:
I am planning to use the methods recommended yesterday where you do not include the 'Disc1', 'Disc 2' within the title.
Cheers,
PaulComment
Hi Oggy,
[ATTACH=CONFIG]1426[/ATTACH]
Cheers,
Paul
You don't need to use, or do anything with these; garym's string does everything for you.
If experimenting with your own naming string, you can see how this works with Compilations, Multi-Disc, and multi-disc, compilations. This work has been done for you.
The only change you need to make if you were to rip, Little Evil, again, is simply tag the Album Little Evil, for both discs, and ensure you use 1/2 2/2. This will give a folder tree of: Miles Davis/Little Evil/Disc 1, Disc 2
On your player, you have a complete, double album.Last edited by Oggy; 08-07-2017, 09:47 PM.Comment
Have posted screenshot/results in my own "Ripping Level" thread; as I did not want to hijack this thread too much.
Hopefully the procedure is correct now - and so other newbies can learn from my mistakes/amendments.
PaulComment
Thanks for the ripping level thread, monsterjacklick, and thanks for the other newbie-oriented discussion. It's been a help. I've now read all of the dbpoweramp ripping forums. Thanks, everybody! After ripping and trying things out, I know just enough to make a thorough mess of it! You all are so smart, I guess my one semester learning Pascal and Basic didn't quite bring me up to snuff! Anyway, here's what I'm trying to do: Rip CD's into two folders (FLAC and ALAC), located on one external hard drive, and using an Acronova NB21 for batch ripping. Using garyn's naming string, I seem to be able to accomplish this, to an extent. My issue is that all of the cd's are ripped as separate tracks, and not as folders (which I'm used to seeing and prefer). There's probably an obvious solution, but it's a puzzle that I just can't solve. Any suggestions?Comment
if you're using my naming string, it automatically creates folders for artists, then folders for albums, then underneath this it creates the individual tracks. Clarify what you mean when you say you don't see folders. Or do you mean that you prefer "cue files" which rip a CD to a single file rather than separate tracks. That's a different thing. Used to be helpful in the old days (to get gapless) but no longer needed.Comment
Welcome Ripsy, I am please you found it useful. All I did really was ask questions and the experienced guys answered! And then I uploaded screengrabs of my findings. PaulComment
