Re: Perfect Tunes scaling problems with high dpi screen
Try this:
http://pocketnow.com/2016/01/25/hidp...-in-windows-10
first with the value as default (copy the whole lot):
<ms_windowsSettings:dpiAware xmlns:ms_windowsSettings=&*8221;http://schemas.microsoft.com/SMI/2005/WindowsSettings&*8221;>false</ms>
then with:
<ms_windowsSettings:dpiAware xmlns:ms_windowsSettings=&*8221;http://schemas.microsoft.com/SMI/2005/WindowsSettings&*8221;>true</ms>
see if these help.
Yes youre right about windows 8.1 I just didnt notice it because I rarely use them..The problem still exists in windows 7 though.Can something be done about that,should I downgrade or should I just have to live with that?..Thanks
In the next few months, work on PerfectTUNES is due to start again, this area will be looked at.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
