Perfect Tunes scaling problems with high dpi screen
  • Thomas Wassholm
    • Jul 2016
    • 13
    I noticed that on my new PC with a 4k 15¨screen scaling seems to be a problem. Some objects look very big while others are very small (see attached screencopy).
    • 43915
    Re: Perfect Tunes scaling problems with high dpi screen
    What is the scaling set to?
    Have you tried a full restart of your Windows?
    • Thomas Wassholm
      • Jul 2016
      • 13
      It is set at 250% which is the recommended value. The big issue is that different objects seems to scale differently. Some are very big and some very small (as you can see in the attached screencopy). Restarting the computer does not make any change.
        • 43915
        250% is supported so something else is happening here. As a test set the scaling to 150%, does that look right? then try 200%
        • Thomas Wassholm
          • Jul 2016
          • 13
          I did try 150 and 200% scaling and everything just gets smaller. The issue is the dropdown menus that are showed with too large fonts.
            • 43915
            They stay the same size no matter what the scaling is set to? how about 100%
            • Thomas Wassholm
              • Jul 2016
              • 13
              At 100% scaling the proportions between the dropdown menus and other objects looks OK although everything is very small. When you increase the scaling everything gets bigger but the dropdown menus gets much bigger as you can see from the three attached screencopies at 100%, 150% and 250%.
ID:	293344Click image for larger version
ID:	293345Click image for larger version
                • 43915
                Even 100% is incorrect as the right hand control should be lined up at the top.
                Which windows do you have? Which graphics card.
                • Thomas Wassholm
                  • Jul 2016
                  • 13
                  I have Windows 10 Home version 1607 (see attached screencopy) and the graphics card(s) are Intel integrated HD 620 and Nvidia Geforce 940MX (see attached screendump)
Name:	Windows version.PNG
                    • 43915
                    Do you have any display extension software installed, such as Window blinds? (that skins the windows)
                    • Thomas Wassholm
                      • Jul 2016
                      • 13
                      No
                        • 43915
                        Do you use dBpoweramp? if so how does batch converter look.
                        • Thomas Wassholm
                          • Jul 2016
                          • 13
                          Yes, I use dBpoweramp and both CD ripper and Batchconverter seems to scale OK (see attached screendump for Batchconverter).
Name:	Batch Converter 250%.PNG
                            • 43915
                            The other perfecttunes programs, do they look right at 200%?
                            • Thomas Wassholm
                              • Jul 2016
                              • 13
                              They all show similar behavior with very big text in drop down menues.
Name:	PerfectTUNES De-Dup 250%.PNG
ID:	293350Click image for larger version
Name:	PerfectTUNES Album Art 250%.jpg
ID:	293351Click image for larger version
Name:	PerfectTunes AccurateRip 250%.jpg
