Multi Encoder - DSP Effects don´t work
  • MDammer
    • Apr 2017
    Use DSP Effects with the Multi Encoder there will don´t work.
    No Conditional check if the file is allready exist, or the Folder.jpg don´t be copied.
    Now i have two diffierent Jobs/Profiles do convert my music from flac to high mp3 and low mp3 codecs.
    Is this a bug?
    And works the DSP Effects with Multi Encoder in the CD Ripper?
    • 43926
    Re: Multi Encoder - DSP Effects don´t work
    Conditional DSP effect will not currently work with Multi-Encoder, it is something we can look at implementing in the future though.
    Folder Jpg cannot be preserved through multi-encoder, unless you use a DSP effect on Music Converter to import the art (ID Tag processing), then export it (on the encoder DSP section).
