id3 tagging problem
  • jsa307
    • Jan 2011
    • 9
    id3 tagging problem
    I've been using dbpoweramp for years without incident, but now have a problem with tagging. When right-clicking on a file, and selecting "edit id-3 tag", the id3 menu no longer displays. When I hover the mouse over the folder icon pinned to the task bar in windows, I see the dbpoweramp/id3 application as "open", but the actual display is not viewable. Strangely, if I select file properties and then navigate to the id3 tab, the dbpoweramp/id3 application is viewable and usable. This is cumbersome, however, and I'd obviously like to restore the original functionality. I tried reinstalling the program, without success. any suggestions? thanks!
    • 43926
    Re: id3 tagging problem
    Which Windows version do you have?
    • jsa307
      • Jan 2011
      • 9
      windows 7 ... but haven't changed that for years
        • 43926
        Try:
        If CD Ripper or Batch Converter appears on the taskbar but the window is not shown, first run a different application so it has focus. Then hover the mouse over the taskbar icon and a small Window will display above the taskbar, right click this Window >> Maximise. Note Vista users look to here: https://forum
