Single track CDs and AccurateRip
  • Hotdog
    • Nov 2015
    • 52
    From what I can gather, is it possible that with a single-track CD, the AccurateRip result might be wrong? I bought a 1-track promotional CD. It was a replacement for a previous copy which had failed to rip last year. When I bought that copy I submitted it to FreeDB. I noticed then and I notice now that there are at least two alternative matches for Metadata so I don't think anyone had submitted the Bee Gees promo CD before then. It's possible they had ripped it and submitted the disc to AccurateRip without entering the metadata. I've ripped the CD and it is inaccurate based on 1 entry. Could it be based on an AccurateRip submission from one of these different titles which has a matching TOC for a single-track CD?
    dBpoweramp Release 15.3 Digital Audio Extraction Log from Friday, January 27, 2017 14:29
    Drive & Settings
    Ripping with drive 'H: [ATAPI - iHAS124 F ]', Drive offset: 6, Overread Lead-in/out: No
    Ultra:: Vary Drive Speed: No, Min Passes: 2, Max Passes: 4, Finish After Clean Passes: 2
    Bad Sector Re-rip:: Drive Speed: Max, Maximum Re-reads: 60
    Encoder: Apple Lossless -v
    DSP Effects / Actions: -dspeffect1="ReplayGain= -albummode={qt}0{qt} -itunnorm={qt}1{qt} -r128lufs={qt}-18{qt}"
    Extraction Log
    Track 1: Ripped LBA 33 to 17610 (3:54) in 1:12. Filename: G:\Music\iTunes\iTunes Music\Music\Automatically Add to iTunes\Bee Gees\You Win Again\01 Bee Gees - You Win Again (7' Fade).m4a
    AccurateRip: Inaccurate (confidence 1) Secure [Pass 1 & 2, Ultra 1 to 2]
    CRC32: 7619F1AC AccurateRip CRC: A457CFDB (CRCv2) [DiscID: 001-000044eb-000089b5-0200ea01-1]
    1 Tracks Ripped Securely (AccurateRip: Different Pressing?)
    Also tried it in EAC:
    Exact Audio Copy V1.1 from 23. June 2015
    EAC extraction logfile from 27. January 2017, 15:08
    Unknown Artist / Unknown Title
    Used drive : ATAPI iHAS124 F Adapter: 1 ID: 1
    Read mode : Secure
    Utilize accurate stream : Yes
    Defeat audio cache : Yes
    Make use of C2 pointers : Yes
    Read offset correction : 6
    Overread into Lead-In and Lead-Out : No
    Fill up missing offset samples with silence : Yes
    Delete leading and trailing silent blocks : No
    Null samples used in CRC calculations : Yes
    Used interface : Native Win32 interface for Win NT & 2000
    Gap handling : Not detected, thus appended to previous track
    Used output format : Internal WAV Routines
    Sample format : 44.100 Hz; 16 Bit; Stereo
    TOC of the extracted CD
    Track | Start | Length | Start sector | End sector
    1 | 0:00.33 | 3:54.27 | 33 | 17609
    Track 1
    Filename C:\Users\Theo\Music\01 You Win Again (7'' Fade).wav
    Peak level 85.4 %
    Extraction speed 6.1 X
    Track quality 100.0 %
    Copy CRC 7619F1AC
    Cannot be verified as accurate (confidence 1) [A457CFDB], AccurateRip returned [8873A968] (AR v2)
    Copy OK
    No tracks could be verified as accurate
    You may have a different pressing from the one(s) in the database
    No errors occurred
    End of status report
    ---- CUETools DB Plugin V2.1.6
    [CTDB TOCID: TLYp3SzoR3HVpBf2_m_IVDdXIO0-] found
    Submit result: TLYp3SzoR3HVpBf2_m_IVDdXIO0- has been uploaded
    Track | CTDB Status
    1 | (0/2) No match
    The CTDB TOCID was found here and seems to suggest "Fable" by Robert Miles
    AccurateRip says my disc is:
    Which aside from the first and last set of numbers, matches the CTDB TOCID for that disc:
    Is it likely that for a single-disc CD the AccurateRip results don't relate to the same disc? I think I've noticed before that a homemade CD-R showed up in AccurateRip which was impossible as it was a few tracks a friend burnt for me, unless someone else was given that same set of tracks and submitted it then I doubt it could be in the database. So I turned AccurateRip off for ripping that CD.
    • 43926
    Re: Single track CDs and AccurateRip
    Yes
    • Hotdog
      • Nov 2015
      • 52
      Thanks, I guess it being secure is enough. I might check it again to see if it matches.
