Sveta Portable Audio Release 4
    • 43926
    To Download:
    Changes:
    Shows Initializing Sveta on start
    WMA v9 now shows all options
    Sveta Explorer - double clicking file in local file list uploads it to portable
    Sveta Explorer - file list type of mp4
    Sveta Explorer - no longer can rename ..
    Sveta Explorer - no longer can delete ..
    Sveta Explorer - no longer counts .. or folders as tracks (total at bottom)
    Sveta Explorer - New 'Audio' button, so can convert or smart convert
    Sveta Explorer - Shows detailed popup info on a local file if hold mouse over the icon for 2 seconds
    Sveta Compression DLL - added a smart conversion mode - click 'smart' and enter formats (or bitrates) that should not be converted, just sent as is.
    Bug Fix: Certain devices would only save the last track transferred in a 'Convert To >> Portable'
    Bug Fix: Stops other Svetas accessing the same device
    Bug Fix: Sveta Add Device was searching for new devices on a 2nd thread, this caused problems for COM object devices (Creative range!)
    Bug Fix: Again Creative devices - this one fixes Ripping CDs direct to Creative device
