Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Multiple Artists and merging tags
  1. #1
    Join Date
    Mar 2016
    I have been exploring the options available in DSP but I have been unable to find out how to do the following:
    1. I have ripped about 1000 albums, and manually divided multiple artist by ";" e.g Artist1; Artist 2; Artist3. (Most of my albums are classical and the three artists are typically soloist, orchestra, conductor) The Naim app only shows Artist1. I manually edited the ID tags on a test album to change the ";" to "," e.g Artist1, Artist2, Artist3. Naim now does show all three artists. My question is how can I make this change for all my albums without going though them manually?
    2. For compilation albums I would like to embed the Composer into the track Title. Is this possible? All my compilation albums are grouped together in one folder, some have various artists, but most have no artists (the metadata obtained through DBpoweramp being incorrect, but not worth entering manually)
    Finally. I understand that batch operations with DSP have to be carried out in the Batch Converter. My music is in flac format. Is it necessary to convert to WAV putting the results in a temporary file, then reconvert to flac?
    I should mention that I run DBpoweramp R16.1 on a Windows 10 PC, and AssetUPNP V5 on a QNAP NAS
    I will appreciate any help with these issues.
  2. #2
    Join Date
    Dec 2008
    Location
    London, UK
    Re: Multiple Artists and merging tags
    Quote Originally Posted by davmurimd View Post
    The Naim app is not able to read multi-value tags, hence the behaviour you are seeing. So, converting Artist1; Artist 2; Artist3 to Artist1, Artist 2, Artist3 converts the multi-value tag to a single tag which will have consequences when browsing the Artist listings.
    You can accomplish this easily using MP3Tag.
  3. #3
    Join Date
    Dec 2008
    Location
    London, UK
    Yes this is possible. Again, you can use MP3Tag or the dBpoweramp ID Tag Update utility codec
    Remember to backup your library, before performing these global tag edits.
  4. #4
    Join Date
    Dec 2008
    Location
    London, UK
    No.
  5. #5
    Join Date
    Mar 2016
    Thank you for your help.
    I found Mp3tag intimidating, but after a few false starts I changed the ; separator to , for multiple artists in the 3 tracks in my test folder.
    I did not manage to add composer to the track title though. I tried the IDTag Update codec, but only managed to add composer to the track (file)name, not the track title.
    Your advice on where to find the required settings would be most welcome.
  6. #6
    Join Date
    Dec 2008
    Location
    London, UK
    In MP3Tag, the Help menu >> Contents is very useful here. You can use the Replace action to replace ; with , (and save it in an action group for future reference).
    MP3Tag:
    Action >> Format value, Field: TITLE, Format String: %title%' ('%composer%')'
    ID Tag Update utility codec:
    Manipulation >> Rule Based Manipulation >> Rule Based Mapping (enter the following)
    IF Title=[anyvalue]
    SET Title=[Title] ([Composer])
  7. #7
    Join Date
    Dec 2008
    Location
    London, UK
    Also, something to bear in mind is that different software often use different display separators for multi-value tags and that the separator can often be file format dependant.
    For flac files, dBpoweramp uses ; as the separator, whereas in MP3Tag the separator is \\, so in dBpoweramp you will see Artist1; Artist 2; Artist3 and in MP3Tag you will see Artist1\\Artist 2\\Artist3 for the same multi-value tag.
  8. #8
    Join Date
    Mar 2016
    Thank you very much for your advice.
    I added composer to the title of about 700 tracks ripped from compilation Cds. I was very impressed by how quick this was using Mp3tag.
    As you suggested, I checked out the changes in the artist listing. This contains the combined artist tags, but I rarely search by artist because I have separate tags for soloist, orchestra and conductor, and I search for these in Advanced Search from AssetUPNP.
  9. #9
    Join Date
    Dec 2008
    Location
    London, UK
    No Problem. MP3Tag is an extremely useful, powerful and flexible tagging tool.
    Yes and remember, you can customize the Browse Tree in Asset UPnP i.e. you could create new containers for soloist, orchestra and conductor.
  10. #10
    Join Date
    Mar 2016
    I tried to recreate soloist, etc. outside Advanced search a while ago, but without success. I must be missing something. I will have another try!
  11. #11
    Join Date
    Mar 2016
    I looked at this again. I can create the containers for Composer, Orchestra, Conductor and Artist/Album outside of Advanced Search, but Chorus, Soloist and Instrument are not shown in the dropdown list of options, and I cannot see how to do this manually, so these remain under Advanced Search.
    Incidentally I have all containers set up identically but orchestra shows only the harp icon. The art shows when the icon for a specific orchestra is opened. Odd!
  12. #12
    Join Date
    Mar 2016
    I used "Merge Duplicate fields" in Mp3tag, setting Artist as the field and ", " as the separator. This did exactly what I needed and avoided worrying about\\
    Thanks again for all your help.
  13. #13
    Join Date
    Dec 2008
    Location
    London, UK
    Chorus, Soloist and Instrument are not in the list, but you can type them in manually.
    Asset uses the images found here: C:\Program Files (x86)\Illustrate\dBpoweramp\AssetImages and you are able to copy existing images and rename them to suit your customizations. There are threads here that explain how to assign icons and how to use use custom tags in Asset (I notice you refer to Soloist and not Soloists).
  14. #14
    Join Date
    Dec 2008
    Location
    London, UK
    Yes, the Merge duplicate fields action is exactly what you need in this scenario.
  15. #15
    Join Date
    Mar 2016
    Chorus, Soloist and Instrument are not in the list, but you can type them in manually. (I notice you refer to Soloist and not Soloists).
    I intended to type Soloists. I first used Custom 3 and 4 in Music Bee for Soloists and Instrument. Later I selected these tags from dropdown lists when ripping from Dppoweramp and sometimes edited them in Edit ID-Tag.
    I'm sorry but I still cannot see how to type in the names of containers manually.
    I do not remember how I set up containers for Soloists and Instrument into Advanced Search, but I am sure it was a very simple process. I have looked at several threads on editing the configuration but I do not see any that refer to assetUPNP running on a QNAP NAS. The only thing I can think of is that I first used Asset on my Windows PC, then had both the PC and QNAP versions running for a while and perhaps I set up these containers in the Windows version and they were carried over into the QNAP version. I uninstalled the PC version some time ago, because I did not use it any more.
    Sorry to be so slow at learning these things. I appreciate you patience.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
