dBpoweramp R16 for Mac OS X beta Discussions
This topic is closed.
    Super Moderator
    • 1365
    Re: dBpoweramp R16 for Mac OS X beta Discussions
    Originally posted by blackcherry
    how do i access the utility codecs in the beta if possible? i'm trying to mass tag replaygain on my older files
    Utility codecs must be enabled first. In order to do so, open dBpoweramp Configuration, Converter tab; there's an "Enable Utility Codecs" checkbox.
    • jfkaess
      • May 2005
      • 105
      Now that R16 has been released, I'd like to put in a feature request for R16.1
      Please add the codec to music converter to convert to .m4b files. This is the file type used by audiobooks, and it has been in the Windows version for many years.
      • spike01
        • Mar 2015
        sorry for my english...
        I make the upgrade to release 16
        Now i get the reference to version 16.0 -> is this normal ?
        thanks
Name:	Bildschirmfoto 2017-03-07 um 19.48.48.jpg
          • 43915
          Try now please (restart Control Center).
          • spike01
            • Mar 2015
            Perfect, thanks for the quick support.
            Greetings from Munich !
            • Number6mi
              • Dec 2012
              • 13
              The upgrade seems really good but have now encountered a significant problem. For a CD with no meta data, when I manually type in meta data and then select ok to accept the meta data, the dbpoweramp goes back to the main screen and then automatically starts trying to retrieve meta data and since there is none it then replaced all the data I've manually typed in! Is there some configuration I need to select to avoid this or is it a bug that needs to be fixed??
                Super Moderator
                • 1365
                Thanks for the bug reports.
                I will be posting R16.1 beta sometime Monday, with fixes for all documented bugs so far.
                  Super Moderator
                  • 1365
                  New beta out as promised:
                  This version addresses all documented bugs in R16 so far. Current version: beta 8 List of changes since R16: Run External DSP fixes: Now accessible again as it was accidentally left out in R16 Updated and bugfixed configuration dialog, options are no longer reversed, the dialog ensures that you input command0line arguments
                  Should no longer look up online metadata after manual editing.
                  New discussion thread for R16.1:
                  Discuss the new beta here. Downloads & release info: https://forum.dbpoweramp.com/showthread.php?39451-dBpoweramp-R16-1-for-mac-OS-beta
