WMA lossless conversion consistently fails with verification errors
Started quite a while back, first with Win 8.1 and now Win 10.
Worked fine for years in Win 7 and 8.1 before that.
Have bought and upgraded to 16.1, reinstalled WMA Pro 10 Rel 9. No change.
Conversions from all 3 of FLAC, ALAC, and WMA to WMA fail at lower sample rate. Bit size remains constant.
Still works fine at same sample rate.
FLAC downconverts to WAV just fine.
Important as it's the intermediate step of the easiest way to convert 24/96 FLAC or ALAC to 24/48 ALAC for iOS - WAV does work but much metadata about file is lost.
Error text:
Error converting to Windows Media Audio 10, 'D:\audio\!!Moved from Dropbox to file\Bruce Hornsby & The Range\Night On the Town\05-Across the River.wma' to 'D:\audio\!!Moved from Dropbox to file\Bruce Hornsby & The Range\Night On the Town\05-Across the River-24.48.wma'
Error audio file failed verification 'D:\audio\!!Moved from Dropbox to file\Bruce Hornsby & The Range\Night On the Town\05-Across the River-24.48.wma'.
Error converting to Windows Media Audio 10, 'D:\audio\!!Moved from Dropbox to file\Bruce Hornsby & The Range\Night On the Town\04-Barren Ground.wma' to 'D:\audio\!!Moved from Dropbox to file\Bruce Hornsby & The Range\Night On the Town\04-Barren Ground-24.48.wma'
Error audio file failed verification 'D:\audio\!!Moved from Dropbox to file\Bruce Hornsby & The Range\Night On the Town\04-Barren Ground-24.48.wma'.
BTW have reviewed with no success:
https://forum.dbpoweramp.com/showthr...e+verification
https://hydrogenaud.io/index.php/topic,59764.0.html
and
Any ideas?
Thx all
Tom
Re: WMA lossless conversion consistently fails with verification errors
What happens if you encode FLAC >> wave (with downsample) then wave to wma with verify enabled?
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
