Accurate Rip
  • BJC
    • Mar 2016
    Accurate Rip
    Why is it that Perfect Tunes Accurate Rip which has already checked my FLAC music taking over 13 hours to do so, is now when I asked it to check my latest conversions/downloads not finding any albums at all despite still using the same music library. Looking forward to a response. Regards BJC
    • 43898
    Re: Accurate Rip
    You ran it once and it generated results, later you run it again and it is showing zero albums?
    • BJC
      • Mar 2016
      Re: Accurate Rip
      Yes, could it be because I had a cable from the external hard drive to the PC when I asked it to read. I cannot recall the setup. Just trying it now without a cable and it appears to work
        • 43898
        Re: Accurate Rip
        Your music needs to be in exactly the same location as when scanned first time.
        • BJC
          • Mar 2016
          Re: Accurate Rip
          It is, it states processing albums then finds nothing.
          I have uninstalled all programs and reinstalled in the hope of it finding them again. It seems to be erratic finding them once then not again then finds them again.
          Confused!!!!!
            • 43898
            Re: Accurate Rip
            The files must not be available, browse to them with Windows Explorer before running the program.
