dMC Level Settings: Encoding Lossless to Lossless
  • dbcamp
    • Feb 2015
    • 24
    This question has probably been posted and responded to in many guises, because my searches fail to turn up a clear-cut answer:
    What is the lossless level setting I should use when I encode one lossless format into another? Take for example converting APE to FLAC. Since both APE and FLAC formats are lossless, I assume that just any of the proffered lossless level options will do. Is this assumption correct, or is there perhaps a hidden spike somewhere I should look out for?
    Thank you for this outstanding application.
    • 43898
    Re: dMC Level Settings: Encoding Lossless to Lossless
    Any setting (compression setting) is ok.
    • dbcamp
      • Feb 2015
      • 24
      Thank you, Spoon, your answer is much appreciated.
