Results 1 to 3 of 3
Thread: Marantz NA6005 network player - can not get dsd to work
  1. #1
    I have Asset 5.1 premium registered version running on a HP LX195 server that has Windows Homer Server version 1. The player and server are connected by wire to the comcast router.
    Flac files of any sample rate play great but I can not get dsd to work. The player is supposed to play single and double rate dsd files. I have a few dsf type files on my server. If I do not change any settings and play a dsf file, music plays but the player says it is playing 96k wav format as if it is being trans-coded. If I change the Audio Format Streaming setting for dsf to stream as dop the player says it is playing a 176k wav format and I only hear noise.
    There are no audio format related settings on the Marantz player so I am not sure what to try next. Has anyone gotten DSD to work? Do you have any suggestions?
  2. #2
    Join Date
    Apr 2002
    Re: Marantz NA6005 network player - can not get dsd to work
    Try setting dsf to 'as single', if the player can play the dsf file it will then.
  3. #3
    Yes that setting worked. Thank you for you help.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
