Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Thread: Adding custom tags
  1. #31
    Join Date
    Apr 2002
    Re: Adding custom tags
    If you cannot edit the value in the web config, then it is right to edit in the AssetUPnPDefinedBrowseTreev4.txt file. After editing you need to restart asset, and do a full refresh all database scan.
  2. #32
    Join Date
    Apr 2014
    Location
    Cyprus
    I found why I couldn't get it to work. There were two .dBpoweramp directories on the system. Obviously only one was in use and I was happily editing files in the other. Once I renamed the inactive directory and edited the other files, I could build a tree with the new tag.
    One final question though. How do I get a similar grouping like for Year (1950s, 1960s, 1070s, etc) with my OriginalDate tag? It contains data like yyyy mm dd, yyyy, or yyyy mm. Thanks!
  3. #33
    Join Date
    Apr 2002
    It will not be possible.
  4. #34
    For the qnap:
    The location of Assets configuration files are: /share/MD0_DATA/.qpkg/Asset/bin/.dBpoweramp/
    for the Pi:
    The configuration files for Asset are stored: ~/.dBpoweramp
    In my QNAP TS-251 I found the file "MediaDatabaseFieldsv4.txt" in /share/CACHEDEV1_DATA/.qpkg/Asset/bin/.dBpoweramp/uMediaLibrary-v2
    Is it the right file/folder to edit ?
  5. #35
    Join Date
    Apr 2002
    Yes
  6. #36
    great, it works
    is there any way to assign an icon to the new Custom Tag instead of the folder icon it gets by default ?
  7. #37
    Ok solved, I duplicated one of the jpg file in "/share/CACHEDEV1_DATA/.qpkg/Asset/bin/AssetImages" and renamed it ORIGINALDATE.jpg
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
