Results 1 to 5 of 5
Thread: 24-bit Conversion Problem
  1. #1
    I seem unable to convert anything at 24-bit. I have tried using source files of 16-bit WAV, to 16-bit alac, flac and mp3, which works fine. However, when I then try and go from 24-bit WAV to 24-bit alac, flac and mp3, the conversion stalls fairly soon in and just stays in lingo.
    Any help?
    Cheers!
    George
    P.S. I am still on free trial edition, if that may be the problem....
  2. #2
    Join Date
    Dec 2008
    Location
    London, UK
    Re: 24-bit Conversion Problem
    Quote Originally Posted by CollinsGA View Post
    Take a single 24-bit wav that you have tried converting to 24-bit alac, flac or mp3 and Convert To >> Test Conversion. Please post the outcome here.
    What platform/OS and which version of dBpoweramp Music Converter is installed?
  3. #3
    Hiya,
    Thanks for the quick response, apologies for my delayed response.
    I did a test conversion using it both in multi-encoder, and Test Conversion alone.
    When in Test Conversion alone, I get this error:
    Information converting to Test Conversion, '/Users/georgecollins/Desktop/test2/GBLLH1543704_04_Anno Winter_44k_24b.wav'
    Unknown LIST sub chunk 'IPRT' Dropping it. [InitFrom]
    When using Test Conversion in multi-encoder, it stalls on this screen:
    I am using OS X 10.9.5 Mavericks, with dBpoweramp 15.3.
    Thanks!
  4. #4
    Join Date
    Dec 2008
    Location
    London, UK
    There is a problem with your 24-bit wav files, hence the error and why you can't convert them.
    Spoon will have to comment on this specific error.
  5. #5
    Join Date
    Apr 2002
    To clarify, you only had 1 encoder listed within Multi-Encoder, that was Test Conversion?
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
