OK, first try:
Asset R4.6.1 beta 2
The beta will function as registered on your system as you've used R4.6 registered before.
I found and fixed a problem similar to what you're describing, but are unable to confirm that what you were experiencing is entirely fixed, as most basic "genre" views seemed to work fine; lots of views under "advanced search" with more sophisticated criteria would not work correctly in R4.6 but should now be fixed.
Update: now at beta 2. Forgot to disable debug code before making beta 1, now fixed.
