Conductor tag problem
  • scompton
    • May 2012
    • 8
    I'm having a problem in the CD Ripper and the Converter with the Conductor tag when ripping or converting to ALAC. In the ALAC file, the tag is visible in the Edit ID Tags dialog, but it isn't visible in foobar or mp3tag.
    • 4015
    Re: Conductor tag problem
    In mp3tag, it is probably called Performer due to your dBpoweramp and/or mp3tag tag mapping settings.
    • scompton
      • May 2012
      • 8
      I don't see a Performer tag in mp3tag. In foobar, Performer is one of the default tags that are always visible whether populated or not and it's empty. I tried converting files from ALAC to FLAC, the tag is copied and visible with all three programs.
        • 4015
        In MP3Tag, select an ALAC with a conductor and type ALT+T, which lists all tags in the extended tags window. What is the name of the tag for a conductor?
        ... don't worry, I have just converted a FLAC (with a conductor and conductor sort) to ALAC and I too do not get any tag for the conductor showing in foobar2000 or MP3Tag at all, whereas, conductor sort is showing. We need to wait for Spoon to comment on this.
        • scompton
          • May 2012
          • 8
          Original FLAC
          ALAC after converting
          ALAC file with conductor after tagging in foobar.
Name:	ALAC with conductor.jpg
            • 43926
            Apple have a document:
            And conductor is @con, which dBpoweramp writes, however foobar and mp3tag do not recognize this tag (instead they write as an generic tag).
            • Henkjan
              • Oct 2010
              • 24
              FIY: see also https://forum.dbpoweramp.com/showthr...l=1*post111132
