Write ID tags; HDCD checked
  • jabberwockie
    • Apr 2014
    • 11
    Under options, metadata, options, write ID tags, I have HDCD "checked" and yet I have several disks that have been detected as being HDCD's but I don’t see the metadata on the files.
    Missing something?
    • 4015
    Re: Write ID tags; HDCD checked
    Originally posted by jabberwockie
    Under options, metadata, options, write ID tags, I have HDCD "checked" and yet I have several disks that have been detected as being HDCD's but I don&*8217;t see the metadata on the files.
    Which platform/OS, dBpoweramp version, output file format?
    • jabberwockie
      • Apr 2014
      • 11
      windows 7, dbpoweramp 64-bit: Registered Reference release 15, output to both flac lossless Uncompressed and apple lossless with DSP effects HD HDCD (+6 dB amplifications "checked)
        • 4015
        In CDRipper with your HDCD inserted:
        1. Do you have HDCD listed for all tracks, under the Track Technical column?
        2. Do you have the HDCD tag listed with a value 'Yes', in the Meta tab, Meta Data for All Tracks (bottom centre of main CDRipper window)?
        If you have neither, what happens if you don't Rip to [Multi Encoder], i.e. Rip to FLAC?
        • jabberwockie
          • Apr 2014
          • 11
          "Yes" for * 1 and *2
            • 4015
            ... and there is no HDCD tag in your ripped flac files?
            • jabberwockie
              • Apr 2014
              • 11
              There is NO HDCD tag in my ripped flac file.
              here is the audio properties:
              Artist Jim Brickman
              Title The Promise
              Album Simple Things
              Track 1/13
              Disc 1/1
              Genre New Age
              Year 2001
              Rating 5
              Composer Jim Brickman
              Size 31.31 MB (29% Compressed)
              Original Size 44.03 MB
              Length 2 minutes 54 seconds
              Channels 2 (stereo)
              Sample Rate 44.1 KHz;
              Sample Size 24 bit
              Bit Rate 2,116 kbps (DVD)
              Encoder FLAC reference libFLAC 1.3.0 20130526
              Encoder Settings
              Audio Quality Perfect (Lossless)
              Contains Album Art, CRC, ID Tag [Vorbis Comments]
              Channel Mapping
              File 01- Jim Brickman - The Promise
              Type VLC media file (.flac) [.flac]
                • 4015
                Artist Jim Brickman
                Title The Promise
                Album Simple Things
                It might not show in audio properties. Two things to try.
                Right-click the same file and select Edit ID-Tag, is HDCD tag listed?
                Have you tried ripping without using [Multi-Encoder]? I have just tested ripping to FLAC only and the HDCD tag is being written (Windows 8.1 64-bit, dBpoweramp R15.3).
                • jabberwockie
                  • Apr 2014
                  • 11
                  HDCD tag was added when I ripped without multi-encoder. Seems to be a bug with the multiencoder.
                  • jabberwockie
                    • Apr 2014
                    • 11
                    HDCD tag was added when I didn't use the multi-encoder. Seems to be a bug with the multi-encoder.
                      • 43916
                      It is just a design limitation.
                      • jabberwockie
                        • Apr 2014
                        • 11
                        HDCD tag is displaying now that I have multi-encoder turned off. Seems to be a bug with the multi-encoder.
                          • 4015
                          Yes, sorry, I alluded to Multi Encoder as a possible cause to the problem earlier in the thread, but I could have been a little clearer.
                          IMO, Multi Encoder is more trouble than it's worth.
                          • jabberwockie
                            • Apr 2014
                            • 11
                            does any of this find its way back to the folks that develop the tool? be good to get this resolved.
                            • Porcus
                              • Feb 2007
                              • 792
                              Weighing in with some uneducated points (I have not ripped CDs with this option);
                              - A lot of CDs are "HDCD" but with no features employed. Could it be that those are not tagged?
                              - Can dBpoweramp now scan and tag without decoding? IMHO one should not decode HDCDs when ripping to lossless (https://forum.dbpoweramp.com/showthr...l=1*post119732)
                              and especially not on a tracks basis - it seems to me (though I could be wrong) that then the HDCD decoding is reset at track boundaries and does not start until a bit into the track: https://www.hydrogenaud.io/forums/in...dpost&p=905120
