Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Filename Character Replacement Not Working
  1. #16
    Join Date
    Dec 2008
    Location
    London, UK
    Re: Filename Character Replacement Not Working
    Quote Originally Posted by adam1book View Post
    It looks like the Batch Converter wouldn't take that much longer to use (only adds one extra step) so I guess you're right. I just started using dBpoweramp so thanks for the info on the workaround.
    Correct. Also, you may find you have to make tweaks to the mp3 tags/artwork etc., which you can do at this stage. Good luck!
  2. #17
    Join Date
    Dec 2008
    Location
    London, UK
    Also forgot to ask, but going back to the second part of my original question, there's no way to replace a colon with a space and a dash in the folder and filenames?
    No, I don't think so.
  3. #18
    Join Date
    Sep 2011
    I wouldn't use Multi Encoder at all. The limitations make it unusable for me.
    However, don't be put off. I too rip my CDs to flac. Then later, when I am happy with the tags, I convert to mp3 from my flac library.
    Other experienced users here do the same. It does have it's advantages.
    +1 Great advice.
    Multi-Encoder sounds....in theory...like a great time-saver, but in practice, it only adds a lot of work if one has to spend time fixing the metadata in two sets of files, instead of one.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
