Does Asset UPnP R4.5 for MAC OS X support DSD (DSF DFF)?
  • zereff
    • Apr 2014
    Just downloaded R4.5 version as registered user. Description of version shows DSD support, but after launch Asset can.t see any of my DSF64 files, though they are tagged properly. Am I doing something wrong or there's no DSD support?
    • 43898
    Re: Does Asset UPnP R4.5 for MAC OS X support DSD (DSF DFF)?
    >DSD and DFF compatibility, decode, send untoched or DSD DoP embed (R5 or newer)
    It is R5 which as DSD support, it will be available shortly for OS X and QNAP.
    • PaulDSD
      • May 2014
      • 35
      Obvious question: what is shortly. I found that with the DLNA server with DSF support, the covert art is streamed to the DAC and therefore notoriously absent. For PCM this is never an issue.
      • dbfan
        • Jan 2011
        • 937
        Hopefully will enter beta test in the next 2 months.
