Any Way To Set Volume Level of Recording When Ripping a CD?
  • Shuttle
    • Jul 2015
    Hi. I would like to know if there is a way to increase the volume level of the recording when ripping a CD? I am trying to rip some CDs using the Apple Loseless Format so I can play them on my Apple Ipod Touch 5. The regular volume level they rip at is a little bit low for my hearing capabilities. Any help would be greatly appreciated.
    • 43919
    Re: Any Way To Set Volume Level of Recording When Ripping a CD?
    If you increase the volume it is likely the tracks will clip, as these days popular cds have no headroom to be increased.
    • Shuttle
      • Jul 2015
      Hi. Thanks for your reply. How can I increase the volume? I'd like to try it and see if I can increase the volume without getting any clipping. Thanks again.
      • BrodyBoy
        • Sep 2011
        • 754
        Apple's Soundcheck can help if this is just a problem with certain albums, but it doesn't work with Apple Lossless. So if you do need volume normalization, you'd have to select a different codec (mp3, AAC, WAV, of AIFF), then turn on Soundcheck in the iPod so that it can scan your library and apply the tags.
        If, on the other hand, the problem is that the level seems too low on everything , I'd check your iPod settings or perhaps try different headphones. iPods have a volume limiter (to protect both ears and headphones), and some headphones can seem noticeably "quieter." (I'm not sure why that is, in technical terms, but I've definitely noticed it.) Also, headphones with incompatible volume sliders (incompatible with Apple's implementation, that is) can cause some volume control issues.
          • 4015
          You shouldn't need to increase the ripped volume levels of the CDs, as Spoon says, increasing these levels will result in clipping.
          Look at the player software on the Apple Ipod Touch 5. If the volume is too low, I suspect this is where the problem lies.
          • Shuttle
            • Jul 2015
            Thanks to all for the input.
