Which DSP configuration is the best for mp3 conversion?
  • Dallaed
    • Jul 2014
    • 29
    Hi! Please, which DSP configuration is the best for mp3 conversion from Flac Files:
    * the high quality options for lame mp3 was selected (320 CBR, Joint Stereo etc).
    1) Bit Depth 32 floatted + Volume Normalize (EBU) + Bit Depth with ditther (return to 16 bits) + Trim Silence.
    or
    2) Volume Normalize (EBU) + Trim Silence
    Thanks and Regards !!!
    Dallaed
    • 43901
    Re: Which DSP configuration is the best for mp3 conversion?
    It probabbly makes no difference, dithering is not required for mp3 as it is bit depth independant.
    • Dallaed
      • Jul 2014
      • 29
      Hi! Thank you for your clarification!
      Dallaed
