Problem extracting audio from mpeg video file
  • jcsouto
    • Dec 2003
    Hi. I tried to extract the audio from a .mpeg video file and although I succeeded in doing so, the resulting mp3 file sounded as if it was being played twice the normal speed (it was a lecture, and it became hard to understand because of that distortion). Anyway I could solve that? Thank you :-)
  • MasterOfPuppets
    • Nov 2002
    • 139
    Re: Problem extracting audio from mpeg video file
    dMC isn't fully compatible with converting mpeg video files, see:
    written by: totalXSive You can't do the whole process with dMC yet, you need to download an extra program to extract the audio. Simply follow these 5 steps: 1. Go to http://www.virtualdub.org/ and download VirtualDub 1.4 - it's free open source software and is only 691KB. 2. Extract the VirtualDub files to a folder
    • jcsouto
      • Dec 2003
      Thank you! Problem solved :-)
      http://forum.dbpoweramp.com/showthread.php?t=21
