Results 1 to 5 of 5
Thread: Help! dBpa doesn't see my intended destination drive
  1. #1
    Join Date
    Mar 2015
    I have a brand new computer that was built just for my music. The computer has an SSD for software and the operating system and a virgin 2TB HD where I want to store my music. I just downloaded a trial copy of dBpa to become familiar with it. I inserted a CD to rip, and opened the Path drop down box to choose the HD as the location for dBpa to place the ripped file.
    The HD did not show up in the available list. It shows up fine in My Computer - no doubt it is there and the system recognizes it. dBpa only saw the SSD.
    I can't find anything that explains why dBpa won't see the other drive or how to edit the path. I found a way that seems to work in JRiver, but I'd rather us dBpa. Can anyone tell me how to make dBpa let me choose the drive I want to use?
  2. #2
    Join Date
    Mar 2015
    Re: Help! dBpa doesn't see my intended destination drive
    Anyone?
  3. #3
    Join Date
    Feb 2014
    What Operating System? Can you store files on the HDD? If it is a Windows system, is your drive formated and has a drive letter?
    Join Date
    Sep 2011
    Quote Originally Posted by jocar37 View Post
    You don't do it with the drop-down menu...hit the "Set" button next to it and you should be able to navigate to the desired target location.
  5. #5
    Join Date
    Mar 2015
    a belated thanks!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
