Results 1 to 3 of 3
Thread: Help - 4 days to index whole library!
  1. #1
    I've just downloaded the trial version, pointed it at my NAS based music folder and got back an estimate of 4 days to index it all (I have 45,000 tracks). And that's with an Ethernet connection, not wireless.
    Would it work if I leave it running, say, overnight and action the results to that point. Then start again the following night. Or does it go back to the beginning and index the tracks already done? Or can I point it to a subset of folders (e'g all the A's, then B's, C's etc) and do it bit by bit (but not one artist folder at a time, I have too many).
    Bottom line is that it's going to be very difficult to leave it for 4 days solid (unless there's a version that runs on Synology, negating the need for the laptop - guess that's a bit optimistic though!)
    Thanks, Phil
    nb I would use it mainly to get artwork. I know I can't actually change artwork with the trial version; if there isn't a workaround with the indexing time I'd struggle to use it though.
  2. #2
    Join Date
    Apr 2002
    Re: Help - 4 days to index whole library!
    You can cancel the indexing and it will pick up where it left off.
  3. #3
    Phew! And thank you for the reply.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
