help
  • Emmanuel
    • May 2015
    help
    Hello.
    I am new.
    I wish information about dBpoweramp CD Ripper .
    Is there a manual in French ?
    to encode what to choose ?
    It ranges from 0 to 8 and uncompressed?
    How to add a personal tag?
    thank you in advance for your lights
    • 43921
    Re: help
    Sorry there is no French manual.
    For most people 5 compression is correct for FLAC.
    Personal tag can be added using the CD Ripper >> Options >> Metadata & id tag
    right at the bottom is 'Add Custom Tag'
    • Emmanuel
      • May 2015
      Re: help
      THanks thanks
      • Emmanuel
        • May 2015
        Re: help
        Hello
        small problem.
        1) when I 2 cd ripping all files are together. there is no file by cd ?
        2) more how do I this information : artist - title - album - track number - year - Custom tag
        what do I put myself as punctuation , how should I encode ?
        Thanks in advance
          • 43921
          Re: help
          How have you set naming? The default naming puts the tracks in Artist then Album folders.
          • Emmanuel
            • May 2015
            Re: help
            hello . how to put two "genre" in a song? what is the method , path to get there ...
            To encode to FLAC, what to choose for future use with SONOS system?
            By default this is set to lossless level 5 .
            what to choose? Thank you a lot
              • 5744
              Re: help
              1. level 5 in FLAC is just related to the size of the file. All levels in FLAC are lossless and SONOS will handle any of them. I personally leave mine at "5" ( a good tradeoff on size of file and time it takes to encode the file).
              2. For multivalue tag for Genre, enter the Genres with ";" between them, e.g., Jazz;Vocal
              after the FLAC rips you can edit the Genre tag with dbpa ID TAG UPDATE or use mp3tag. In mp3tag, separate the two genres with "\\", e.g., Jazz\\Vocal
              However, I'm not sure that SONOS can handle multitag values. Someone else will have to chime in on this.
              • Emmanuel
                • May 2015
                Re: help
                Hello. some details in relation to my question on
                "Genre".
                Can I put a space between two tags?
                example
                Jazz ; Vocal or may be better Jazz;Vocal ?
                thanks
                • BrodyBoy
                  • Sep 2011
                  • 754
                  Re: help
                  Unfortunately, Emmanuel, I must warn you to NOT use multi-value GENRE tags for Sonos. :( It will not use them.
                  Sonos does not recognize the semi-colon separator, so it will not see "Jazz" and "Vocal" GENREs in your example above. And what's worse, it doesn't just use the one of them. Instead, it will create a new GENRE called "Jazz/Vocal," which will be separate from both "Jazz" and "Vocal" (for search purposes, etc).
                  This has been a problem for Sonos users for a very long time.
                    • 5744
                    Re: help
                    "Genre".
                    example
                    thanks
                    Keep in mind that the ";" or "\\" in mp3tag is just telling the system to create multivalues. In a FLAC file, if you look at the tags after the fact with multivalue it actually has TWO separate tag fields, looking like:
                    Genre: Jazz
                    Genre: Vocal
                    They are not actually two values within a single field.
                    • Emmanuel
                      • May 2015
                      Re: help
                      Good morning I need help.
                      I have a tagging problem.
                      I can't change the genre of multiple flac files.(see pictures)Click image for larger version
ID:	294263Click image for larger version
                      What should I do?
                      Thank you in advance
                        • 5744
                        Re: help
                        What is the F drive? is it NAS or network drive? If so, perhaps you haven't setup permission to write to that drive.
                        • Emmanuel
                          • May 2015
                          Re: help
                          Good evening,
                          it's an external hard drive.
                          I've been working on this one for a few days with no problem making changes.
                            • 5744
                            Re: help
                            Good evening,
                            look at one of these file's properties and make sure it is not "write protected".
