LUFS Target Volume option in EBU R128 Volume Normalize DSP Effect
  • JII
    • Mar 2015
    • 18
    Unless I'm mistaken EBU R128 Volume Normalize DSP Effect is fixes to -23 and lot of us are using -18.
    Were it not possible to add an option to change it, like in ReplayGain DSP Effect ?
    Thank's a lot.
    • 43926
    Re: LUFS Target Volume option in EBU R128 Volume Normalize DSP Effect
    You can offset it with the volume adjuster on the far right.
    • JII
      • Mar 2015
      • 18
      Thank for your rapid answer. But I need offset it of +5 and the cursor give only negative values ? Ah ok, I just realized that I can enter it manually. Thanks.
      And what about "disable clipping prevention" option ? Is it enable or not ?
      Thank you.
        • 43926
        I not think clip prevention is in this dsp effect.
        • JII
          • Mar 2015
          • 18
          Thank you, that's a good news.
