Add button not highlighted
  • clear_energy
    • May 2010
    Can someone please tell me why the add button will not highlight? I can select a folder but when it comes time to see the individual songs in a folder they don't even show up. Nor can move anything to the box where the add button highlights. I'm stumped...
    • 43901
    Re: Add button not highlighted
    What type of audio files are they?
    • clear_energy
      • May 2010
      flac and mp4 files. I am using windows 7 and newest dbpoweramp version which I believe supports 64 bit. Is it that the writer does not support 64 bit? Thank you.
        • 43901
        It does not, please see:
        The 64 bit release of dBpoweramp will only work correctly with 64 bit codecs. In Codec Central the codecs which are indicated as 32 bit only will not work with the 64 bit version of dBpoweramp. CD Writer CD Writer cannot be compiled to 64 bit, it is 32 bit only.
        • clear_energy
          • May 2010
          That's disappointing. You spend $20 for a 64 bit version and then you can't use the full program without manipulation. Why even roll out an updated version if it isn't full and complete? Will the writer ever be compatible with Windows 7, 64 bit? This sort of doesn't make sense...
            • 43901
            We would have to rewrite it from scratch to support 64 bit, it is not currently planned.
