NOTE: Any posts to this forum on or after 16th April will disappear in few days when we transition to a new forum
Results 1 to 3 of 3
Thread: 24-Bit/44,1khz to CD Quality 16-Bit/44,1khz, DSP Effect?
  1. #1
    Join Date
    Feb 2014
    Location
    Antwerpen
    Hi there,
    I was wondering im creating a DVD-Audio disc with DiscWelder Chrome and i got WAV masters in 24bits 44,1khz.
    I want to put a Group on the DVD-A with CD-Quality Files and one Group with the 24 bits 44,1khz files.
    Since the sample rate 44,1khz is the same as CD-Qualitythen i dont need a DSP effect to resample it to 44,1khz right?
    So if i want to convert to a CD quality version 16 bits then the only DSP effect i need is "Bith Depth" with settings to 16 Bits Fixed and Dither settings at "TPDF".
    This should be enough right ?
    I don't need to add the resample DSP effect at 44,1khz since the sample rate from the 24 bits masters is already 44,1khz ? the studio masters are also 44,1khz like CD only the bits are higher...
    So my wild guess is i'm doing it right this way ?
    I'm only needing "Bith Depth" DSP effect when i downconvert to a 16 bit version with settings as 16bit fixed and Dither at "TPDF" (i believe that's triangle)...
    Any info would be great !
    Thanks in advance !
  2. #2
    Join Date
    Apr 2002
    Re: 24-Bit/44,1khz to CD Quality 16-Bit/44,1khz, DSP Effect?
    You are 100% correct.
  3. #3
    Join Date
    Jul 2010
    The difference between 16 bit and 24 bit is extra zeros.
    16 bit: 0000000000000000
    24 bit: 000000000000000000000000
Posting Permissions
  • You may not post replies
  • You may not edit your posts
