Results 1 to 9 of 9
Thread: Issue while converting FLAC to WAV --> noise between tracks
  1. #1
    Join Date
    Mar 2015
    Hi, I am wondering how to fix the following issue: I have converted FLAC to MP3 w/o any issue. When doing the same from FLAC to WAV, I have a 1 second "big" noise between each track which is not very good while listening the music!
    Any idea how I could fix the issue?
    Many thanks,
    Laval
    I am on Windows 7
  2. #2
    Join Date
    Dec 2008
    Location
    London, UK
    Re: Issue while converting FLAC to WAV --> noise between tracks
    What player are you using?
    I suspect the player is unable to read wav files that contain metadata.
    You have to disable the Wave ID Tagging in dBpoweramp Configuration>Codecs>Advanced Options. Try it and see if the noise disappears.
  3. #3
    Join Date
    Mar 2015
    it is actually in my car, using a USB3.0 stick (Mercedes, 3years old);
    ok thank you, I am trying now and I tell you the result.
    So in the Wave ID Tagging, for Tag Creation, i have selected (none), instead of initially (default - LIST & ID3)
    Join Date
    Dec 2008
    Location
    London, UK
    Quote Originally Posted by Laval View Post
    correct
  5. #5
    Join Date
    Mar 2015
    it works fine now! Many thanks!
    So, what type of metadata I am losing with this new set-up?
  6. #6
    Join Date
    Apr 2002
    All metadata, your wave files are untagged.
  7. #7
    Join Date
    Mar 2015
    I am sorry, what does it mean?
    For example, I still see the album, artist and track names
  8. #8
    Join Date
    Nov 2014
    Location
    Halle, Belgium
    Many thanks,
    Laval
    I am on Windows 7
    hi dear laval
    why do you wanna or try because it will not work or better yet, you will not hear a difference in audio quality just enlargening the file/song/track , probably there lies your problem , as you can hear that from flac to Mp3 ,did a good job , as seen here
    but good luck , with your problem
    Win 8.1 64 bit
  9. #9
    Join Date
    Nov 2007
    Location
    Florida, USA
    It may be that the car player reads the file names (as opposed to the metadata) of your files (and these may contain album, artist, track names).
Posting Permissions
  • You may not post replies
  • You may not edit your posts
