Results 1 to 3 of 3
Thread: QNAP TS-470 Pro and Asset UPnP
  1. #1
    Join Date
    Aug 2008
    Location
    Netherlands
    It is time to replace my NAS and I want my new NAS to run Asset natively.
    I am considering the QNAP TS-470 Pro with an Intel® Core™ i3-3220 3.3 GHz Dual-core Processor.
    Before making this purchase I would like to confirm that Asset will run on this NAS.
    Will the QNAP Release 4.4 Intel (n51, n69, n69L, n70, n53pro, HS-251 where 'n' is 1, 2, 4, etc) also run on the Pro version?
    Join Date
    Apr 2002
    Re: QNAP TS-470 Pro and Asset UPnP
    Yes it will.
  3. #3
    Super Moderator
    Join Date
    Jul 2011
    All ARM models and Intel Core models are supported.
    The only models we do not currently support are Intel Atom 32-bit models - 259/459/659/859 and the new 269h - reason being that they're all either very expensive or hard to find, usually both. Intel Atom based models running 64-bit Linux are supported (269/469/... series).
Posting Permissions
  • You may not post replies
  • You may not edit your posts
