Multi CPU-Force not working
  • schorsch
    • May 2012
    • 15
    Hello,
    since upgrading from 15.1 to 15.2 I have the "problem" that converting files from .wav to .flac is now done only one file after the other.
    Before (with 15.1) I saw all of my 8 CPUs working simultaneously (even without the need of using "Multi-CPU Force") but with 15.2 (without changing any of the settings) only one file is shown respectively converting.
    The encoding speed before with up to 8 CPUs was about 4 to 5 times higher (often more than x1000). I now tried several settings with the Multi-CPU Force (ticking the boxes CPU 1 to 8 with "Do Not Ally to Processor" checked respectively unchecked) but no improvement.
    I know that while converting from .flac to .wav only 1 CPU is working but the other way round all 8 CPUs were in use.
    Using the Batch Converter shows exactly the same behaviour; any ideas how to get the "High Speed Converting" back ;-)
  • BrodyBoy
    • Sep 2011
    • 754
    Re: Multi CPU-Force not working
    I'm thinking that 15.2 didn't install as "registered." When you open the Configuration pop-up, does it show as registered?
    • schorsch
      • May 2012
      • 15
      Yes, it does show as registered.
      • BrodyBoy
        • Sep 2011
        • 754
        Sorry..I misspoke! I meant "Reference." Multi-CPU encoding requires dBp Reference. Assuming you are using Reference, Spoon will have to weigh in with more technical expertise on what would be forcing one CPU conversions.
        • schorsch
          • May 2012
          • 15
          I just uninstalled the program and cleared the registry with dBpoweramp-Reset. After the new installation everything is back to normal and working fine ;-)
          • BrodyBoy
            • Sep 2011
            • 754
            Interesting. It'd still be nice to know what was going on there! Spoon....?
              • 43926
              It is possible 2 dbpoweramps were installed.
