where is perfect tunes searching for cover art?
  • Flotek
    • Feb 2015
    i purchased PT but i'm disappointed. from 625 missing covers PT found 225.
    when i'm searching with the same search strings PT is using i find immediately most covers as first result on google picture search.
    cant i set PT to use google for searching?
    • 43901
    Re: where is perfect tunes searching for cover art?
    Click the fix button for any albums which it cannot automatically fix.
    • Flotek
      • Feb 2015
      "fix it" doesn't deliver any result but google does!
      example: The Jive Aces - Our Kinda Jive
      result fixit, just nothing:
Name:	fix result.jpg
      result google, just perfect:
      understand what i mean?
        • 43901
        Try the latest test version of PerfectTUNES and make sure your security software is not blocking it (or partially). When I run Album Art and change the album search to:
        I get 62 results listed.
