Converting from FLAC to WMA - ID Tags and Artwork are missing
  • Robbo-UK
    • Jan 2014
    • 8
    Seeking the wisdom of others on this please: I am converting FLAC to WMA (9.2). The source FLAC files have all of the ID Tags, Metadata, and artwork present. But after the conversion, the resultant .wma files have nothing. They play OK, but it's a bit frustrating to lose all of that info. Where should I look to see which tick-box I have missed ?
    Thanks guys,
    Robbo.
    • 43919
    Re: Converting from FLAC to WMA - ID Tags and Artwork are missing
    Right click on the FLAC file >> Edit ID Tags, are ID Tags shown in dBpoweramp tag editor?
    Then do the same for the created WMA files, are tags shown?
    • Robbo-UK
      • Jan 2014
      • 8
      FLAC files - all ID Tag info is there
      WMA files - no ID Tag info there
      See attached screenshots:
        • 43919
        On the wma tag window, what happens if you try to manually add a new tag? click ok, then edit tags again does it show?
        • Robbo-UK
          • Jan 2014
          • 8
          OK, so as a test I converted a FLAC file twice to the same test directory. One conversion to mp3, one conversion to WMA - as you can see from the attached directory listing (screenshot 1). The ID Tags have converted to the mp3 file absolutely fine, as you can see on screenshot 2. But there are no ID Tags on the WMA file. When I try and add a Tag, I get an error - as you can see on screenshot 3. Why does the mp3 conversion create the tags, but the WMA conversion does not ? I can edit the Tags on the mp3 file - as you can see on screenshot 4 - so I must have the correct permissions to the directory.
          Thanks for your help on this.
            • 43919
            Are you able to convert from a WMA file which is tagged to mp3, are the tags transferred?
            • Robbo-UK
              • Jan 2014
              • 8
              Sorry Spoon, not sure I understand what you are asking here. I think you are asking me to convert a WMA file to an mp3 file. Is that right ? The problem is that I do not have a WMA file which has ID Tags. So I cannot convert a "WMA file which is tagged" to mp3. I could convert an WMA file which has no Tags, to mp3, and then see if I could add tags to the mp3 file. Is that what you need me to do ?
              Or could you upload a WMA file which has Tags ? I could then download and do the conversion to mp3, to see if the Tags get converted.
                • 43919
                This one is tagged.
                • Robbo-UK
                  • Jan 2014
                  • 8
                  OK- I downloaded and extracted it.
                  Odd that I see no ID Tags - see screenshot *1
                  But if I play it, somehow WMP "knows" the title - see screenshot *2
                  And if I try to convert the WMA file to mp3, the conversion fails - see screenshot *3
                  I'm thinking that I must have the wma codec installed, as I can convert to WMA ? ? ?
                  Confused
                  • Robbo-UK
                    • Jan 2014
                    • 8
                    OK I've checked on the dbPoweramp config page
                    I have wma codec listed under "write" - see screenshot *1
                    No wma codec listed under "read" - see screenshot *2
                    Do I need a wma "read" codec then ? If so, how do I get it ?
                      • 43919
                      Uninstall the WMA codec, and reinstall.
                      Check that your security software is not blocking our WMA.DLL decoder.
                      • Robbo-UK
                        • Jan 2014
                        • 8
                        Sorted !! Those 2 steps have done the trick.
                        Many thanks, Spoon
                          • 43919
                          Which security software was blocking it?
                          • Robbo-UK
                            • Jan 2014
                            • 8
                            I think the removal and re-install of the Codec was what did the trick. But I did also add a shedload of dbPoweramp files to the list of allowed applications in my Kaspersky Internet Security. Probably overkill, but it works, so I'm leaving it as-is.
