Volume control
  • alk630
    • Jun 2014
    • 89
    Volume control
    Please excuse my ignorance on this subject, which I am fairly new to. I have an Arcam Solo Neo, which until recently I used to play FLAC files over the network using Asset UPnP on a Win7 x64 system and selecting the albums and tracks on the unit itself, which was very cumbersome. Next, I discovered Asset Control, which worked almost flawlessly until I left it to play a few tracks, when it started to hang. I then tried Kinsky, which works almost perfectly in conjunction with Asset UPnP and BubbleUPnP Server, until I try either muting or adjusting the volume, which causes my Arcam to hang until I turn it off and back on again. I was just wondering which piece of software is likely to be the cause of the problem and if possible an explanation as to why?... is it Asset UPnP or Kinsky or is the problem likely down to my Arcam hi-fi?
    Is it likely I can do anything to try and rectify this problem and, if so, how? Any help would be greatly appreciated.
    • 43901
    Re: Volume control
    Volume is done directly on the player through the control point.
    • alk630
      • Jun 2014
      • 89
      Re: Volume control
      The same problem with the volume controls causing the Arcam to hang also exists in Asset Control. Is this because of limitations with my hi-fi UPnP or is there some kind of easy fix that could be made to Asset Control?
        • 4015
        Re: Volume control
        What do Arcam say about the unit hanging?
        • alk630
          • Jun 2014
          • 89
          Re: Volume control
          They don't say much at all mville, they are very elusive and difficult to contact. One representative did get back to me to say that this was now an unsupported unit, although it is still on sale and advertised on their site. It is frustrating that hi-fi producers seem to expect their customers to pay thousands upgrading to the latest and greatest and offer little in the way of genuine support for problems. I don't even know whether this is an Arcam problem or a control point problem.
          • alk630
            • Jun 2014
            • 89
            Re: Volume control
            Apparently the Neo doesn't support volume commands over UPnP. The Neo will attempt to ignore the commands but they can cause it to crash. There is no solution to this as the Neo was designed on the UPnP spec of 4 years ago and is a discontinued model.... just in case someone else is looking for an answer to the same question.
