ReplayGain Utility Codec Issues
  • Rafal
    • Oct 2014
    • 11
    Re: ReplayGain Utility Codec Issues
    Also note that the qobuz tracks are not Hi-Res. Hi res is 24/96 or 24/192 files. Qobuz files are 16/44.1 flac files equivalent to CDs.
    Qobuz, at least in my part of the world, sell 24/88.2, 24/96, 24/192, and 16/44.1.
      • 5743
      sorry, yes you are correct. I'm thinking of the FLAC *streaming* that they do, which is 16/44.1. I don't have many hi-res files, but I believe that I used dbpa in the past to do a flac to flac conversion of 24/96 files retaining the hi-res data (bit perfect). To test this for yourself, convert a file to flac, then on the original file and the converted new file, run a "conversion" to dsp "caculate audio CRC" on each of these flac files. The CRC should be identical between the two files (bit perfect audio). One can also use foobar2000 to bitcompare the audio between two tracks.
        • 43898
        All conversions of FLAC to FLAC are 100% identical.
