Arrange Audio Arrange audio tracks based on ID Tags (Requires Reference)
  • dyet
    • Jul 2004
    • 35
    Hi
    I installed the latest release (15)
    I had to reinstall Arange Audio codec from the dbpoweramp (latest release)
    But what's happening is when I select the files and go to the drop downdown list Arrange Audio isn't listed?
    I rebooted my computer etc.
    Any suggestions?
    (see attached)
    • 43919
    Re: Arrange Audio Arrange audio tracks based on ID Tags (Requires Reference)
    You must have 32 bit and 64 bit installed, see:
    The 64 bit release of dBpoweramp will only work correctly with 64 bit codecs. In Codec Central the codecs which are indicated as 32 bit only will not work with the 64 bit version of dBpoweramp. CD Writer CD Writer cannot be compiled to 64 bit, it is 32 bit only.
    You have to delete the 32 bit folder, otherwise the 32 bit codecs install.
