R15 64bit and R14 32bit on Win7 together
  • doobre
    • May 2006
    • 47
    just installed R15.1 and afterwards thought that I should have perhaps UN-installed R14 first. but i need the CD ripper and I read here that there is only a 32bit version..
    I can see the new folders where the R15 has been installed "program files\dbpoweramp\..." rather than the "program files (x86)\\illustrate folder\dbpoweramp" for the 32bit and both folders contain a "CDGRAB.exe"..
    How to make sure that the 64bit version of the converter etc. is used for all tasks automatically with the exception of the CD ripper..?
    During the installation did you cleverly make R15 64bit to be chosen as the default by windows exclusively or can both 32 and 64 versions still be used..?
    cheers
    CD
