Results 1 to 9 of 9
Thread: Correction Offset Missmatch
  1. #1
    Exclamation Correction Offset Missmatch
    Hi there!
    I try to get Accuraterip working on my second drive, model ASUS SBC-06D2X-U.
    But everytime i put a key disc in the drive, i got a window with this message "AccurateRip will not key to this offset as it miss-matches the drive database offset. [ Calculated offset value + 103 samples, + 412 bytes. ]
    I checked the database and it seems like the correction offset for this drive is +48.
    What is the procedure to follow to run Accuraterip on this drive?
    Thanks in advance.
  2. #2
    Join Date
    Apr 2002
    Re: Correction Offset Missmatch
    How many discs have shown that offset? and are the discs not part of a single box set (or compilation).
  3. #3
    I retried with 3 different discs (Adema - Adema; Adema - Insomniac's Dream EP; 311 - From Chaos), but i have tested many more key discs and the calculated offset value is always +103 samples, +412 bytes. Tried Faith no More - Who Cares a Lot as i'm writing this message and got again +103 samples, +412 bytes.
  4. #4
    Can you try to add this drive or maybe change the offset in the database?
    How drives if the same reference can give different offsets?
    Join Date
    Apr 2002
    The next monthly update, we will purge this drive from the database, so that it will key using 3 discs.
    All drives are supposed to have a consistent offset, and they do, there is a handful of drives which seem to change over time.
  6. #6
    When is the next monthly update?
    I will try it again after the purge.
    Thanks a lot
  7. #7
    Join Date
    Apr 2002
    Beginning of the month, then it might take 1 week for the drive settings to get to your computer.
  8. #8
    Is it possible to see the status of the purge for the ASUS SBC-06D2X-U?
  9. #9
    Join Date
    Apr 2002
    Sadly the removal had an error, I have corrected this error however the regeneration of the database is 4 weeks away.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
