CD Ripper not finding CDs in AccurateRip db or metadata and artwork
  • bcam
    • Jun 2014
    Just installed R 15 and have 'test' ripped 15 - 20 cds, none of which have been found in AccurateRip nor has any metadata or art work been found. I'm ripping from a Win7 PC using Multiencoder to create FLAC files on the PC and AIFF files on a network-attached Mac Mini. The rips have all been successful. I have gone through the settings several times looking for anything that might be obvious to a new user . The only possible hint of trouble is that when I tried to check for software updates through Configure dbPoweramp I got a message 'Unable to connect to dbPoweramp .com, check internet connection and Windows firewall'. The internet connection was fine and I turned off the firewall. Didn't help; still can't check for updates or find the CDs in AccurateRip. Any help will be appreciated.
    • 43901
    Re: CD Ripper not finding CDs in AccurateRip db or metadata and artwork
    Check in dBpoweramp Configuration >> Music Converter >> Allow dBpoweramp To Access Internet that this is checked.
    If every aspect of dBpoweramp cannot access the internet, then you definitely have a firewall which is blocking dBpoweramp, it is difficult for us to advise on that because there are so many different firewall programs (and anti malware, etc), perhaps contact the manufacturer of these respective programs and determine if they can unblock it..
    • bcam
      • Jun 2014
      Thanks. 'Allow to access internet' is checked and all was ok on R 14 before I upgraded a few days ago. I just noticed that after I deinstalled R 14 and installed R 15 there are a couple of R14 modules ([Cue Sheet Image Codec] and CD Writer) that were not deinstalled. I'll try to get rid of those to see if that makes a difference and if not will download R 15 to a different PC (Win8.1) which does not have R14 on it.
        • 43901
        I do not think uninstalling these items will help.
        • Hitarth
          • Sep 2017
          • 151
          hello ! Mr Spoon,
          I had been using R16.3 for some time & all was going well & not I upgraded to R16.4 ... here too all is going well except, I cannot seem to get any art work on clicking the "disc" to open the next screen to make a choice of the cover .... I have also "allowed" dBpower thru the windows firewall ... but still no luck .... I have no problems with the other meta data ... please help !!!
            • 43901
            Using CD Ripper? do you get album art for popular discs without clicking the disc image?
            • Hitarth
              • Sep 2017
              • 151
              Yes Sir,
              it does pick up the cover .. BUT what happens in many cases is .... it picks up the wrong cover ... like for eg. : "Now That's What I Call Music" it could pick up the back cover ...& if I want to find the front, I would click on the "CD" icon on the dBpower to get a choice ... generally, on clicking it would open up the page with a large number of choice ... but that doesn't happen.
                • 43901
                Try a popular CD, does it show any art?
                • Hitarth
                  • Sep 2017
                  • 151
                  yes sir, it does.
                  attached is a popular Cd, but this is no the right cover. so if I click the CD to get the choice of covers available, I see the same cover.
                    • 1745
                    But it is the right artist and album, and only the "wrong" album art?
                    • Hitarth
                      • Sep 2017
                      • 151
                      yes, sir !
                      it is only the album art problem.
                        • 43901
                        and you never get any art which clicking on the disc image (or art image) for any disc?
                          • 1745
                          You know that a album can have different covers, depending on the target market? Aside of that: from what I know, dBpa only searches for the artist and album name. So even in case of different pressings it can happen that dBpa finds identical cover.
                            • 4015
                            Originally posted by Hitarth
                            [ATTACH=CONFIG]1971[/ATTACH]
                            The official Mariah Carey - Greatest Hits, was released worldwide on Columbia (Sony Music) in 2001. The artwork showing in your screenshot, is the right artwork for this release.
                            The track listing in your screenshot is different from the release I mention above and the Year is showing as 1984, whilst her first releases weren't until 1990. So, something is wrong here.
                            What album title, label and year is printed on your CD artwork/disc?
                              • 1745
                              Good point, mville! In 1984 Mariah has been 14 or 15 (year of birth differs on 1969 and 1970) years old - a bit to early for her Best of album.
