Results 1 to 6 of 6
Thread: Accuraterip will not configure in EAC
  1. #1
    Hi all, I'm going round in circles and need some help. I recently upgraded my HDD to SSD, nothing else changed. Prior to this, my drive had configured perfectly with AR in EAC; all was fine with the world. Since the upgrade and fresh reinstall of Windows, my drive will no longer configure with AR and I can't work out why. I've been through getting on for nearly 100 discs and I'm pulling my hair out. I've had every error message I think AR can generate and I can't for the life of me work out why it won't work when nothing's changed on the hardware front (other than the SSD). I've updated the drive firmware to the latest (drive is a tsstcorp cddvdw sh-s223c and is now on firmware SB07
    I've used known Key Discs such as Dream Theater's 'Images and Words' and still no joy. Here are the error messages I've received:
    <---------- this is the most frequent error
    What can I do to get up and running again? I've scoured forums and the like to try and find a fix myself but I'm stumped....
  2. #2
    Join Date
    Apr 2002
    Re: Accuraterip will not configure in EAC
    Can you try another 3 different discs, if it gives 696 I will purge the drive from the database, this drive appears to be quite unique, in that there seems to be 2 different offsets for it, where these should only ever be 1 constant offset.
  3. #3
    Hi Spoon,
    Found another three that give 696; Feeder 'Comfort in Sound', K's Choice 'Cocoon Crash' and Kid Loco 'Prelude to a Grand Love Story'.
    Cheers, appreciate you looking into it.
  4. #4
    Join Date
    Apr 2002
    Ok, will take about a week for it to propagate through.
  5. #5
    Many thanks!
  6. #6
    Join Date
    Jun 2014
    I have the same drive and right now, it doesn't show any offset at all. Just the warning in the middle of Funkmeister's first post. Spoon, could you give a little update to what people with this drive should do now considering AccurateRip?
    When I visited AccurateRip's website I have also noticed that the drive is purged now. To me, this doesn't sound very good. What's the alternative, then?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
