Problems with Batch Ripper
    • 43921
    Re: Problems with Batch Ripper
    Perhaps you have overread enabled in CD Ripper? or are ripping to a network share, both of these can freeze the ripping (it must be pointed out it is not CD ripper at fault).
    • ricsimas
      • Mar 2011
      • 11
      I'm assuming over-read is set by that Read into Lead-In Lead-Out setting? If so, it's disabled. I'm defaulting to Secure Ripping, by the way, and, as I mentioned, everything works in the regular CD ripper (if these settings are available separately for the Batch Ripper, I couldn't find it).
      As for the network share comment: it's ripping to a local drive. This drive is set as shared over the network, but I'm assuming this is not what you meant by network share?
        • 43921
        It all seems good, you can right click on the drive in Batch Ripper and select 'Show Ripper', batch ripper uses the normal CD ripper (hidden) for ripping.
