Results 1 to 3 of 3
Thread: FDK aac encoder bandwidth never goes beyond 20 KHz even after setting -w 22050
  1. #1
    Join Date
    May 2014
    Lightbulb FDK aac encoder bandwidth never goes beyond 20 KHz even after setting -w 22050
    FDK aac encoder bandwidth never goes beyond 20 KHz even after setting -w 22050 (cutoff freq) which does not happen in itunes aac or winamp Fraunhoffer aac. I looked through source code to find out but I am not that experienced I guess. That is why I am posting it here. I am posting two images one is from itunes aac and another (which showing 20 KHz) is dbpoweramp fdk. Using updated FDK version 3.4.12 which I compiled this morning ! Hope somebody fixes this issue. Other wise sound quality is fine.08 - Medicine (feat. Blake Shelton).m4a.jpg
  2. #2
    Join Date
    Apr 2002
    Re: FDK aac encoder bandwidth never goes beyond 20 KHz even after setting -w 22050
    It is likely the codec overrides the frequency cut off depending on bit rate. For a lossy codec potentially there is better overall quality by cutting the frequencies, because most people cannot hear that high.
  3. #3
    Join Date
    May 2014
    Thank you for the info spoon.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
