Problem reinstalling CD Writer after upgrade to dMC R15
  • drm54
    • May 2014
    Hello,
    I uninstalled my previous R14.4 version of Music Converter before installing R15, however, I indavertently also uninstalled CD Writer.
    I found that I still had a prior .exe file for CD Writer, but I am unable to get R15 to recognize CD Writer and offer the option of burning to audio CD.
    When I try to run CD Writer alone, it says "CD Writer requires Music Converter Reference R13 or newer".
    Is there a way I can get dMC 15 and CD Writer to talk to each other?
  • drm54
    • May 2014
    Re: Problem reinstalling CD Writer after upgrade to dMC R15
    I realized the source of the problem - I overlooked the fact that in order to have R15 work with CD Writer, it has to be installed as 32 bit. I had installed R15 as 64 bit, which I believe is the default.
    An uninstall followed by a re-install as 32 bit (holding down the right shift key) corrected the situation.
    • paisleyparker
      • Mar 2013
      good evening,
      how about an updated 64-bit CD Writer compatible with R15?
      thank you,
      enjoy,
      PP
