Stream PC Sound
  • Masek
    • Apr 2014
    Stream PC Sound
    i purchased Asset UPnP because it said with the registered version, you can stream your PC sound. I have not found any setting to do this. How do i tell Asset to stream the PC standard sound?
    Yours, Martin
    • 43898
    Re: Stream PC Sound
    When you browse the root menu you select [PC Audio Capture]
    • Masek
      • Apr 2014
      Re: Stream PC Sound
      Thanks, i got it now....
      Unluckily i do not achieve what i aim for but probably the cause is not with Asset UPnP.
      I want to get rid of my PC speakers and use the Sonos devices as speaker. While i get the PC sound, it is delayed by several seconds so it is of no use....
      Thanks anyway, Martin
