Asset UPnP on Raspberry Pi buffering in middle of every track
  • simes_pep
    • Dec 2013
    • 288
    #31
    Re: Asset UPnP on Raspberry Pi buffering in middle of every track
    Can you apply this Beta version over a Licensed version and retain the 'Premium Registered' status.
    Simon.
      • 43922
      #32
      Yes
      • simes_pep
        • Dec 2013
        • 288
        #33
        Applied the Beta - noticed some database issues, with it Skipping some tracks, so rescanned.
        Now getting 'Library Contains 20229 Tracks, 1 Albums' with all tracks as one Album.
        So back to the Release version.
        Simon.
          Super Moderator
          • 1365
          #34
          simes_pep,
          We cannot reproduce the issue you're having with the beta - it looks as if some part of the Asset archive did not extract correctly. Can you please try the beta again?
          If you run into '1 album' scenario again, we would very much appreciate if you could email us your Asset configuration data.
          Commands to produce an archive of your Asset configuration-
          tar czf ~/AssetConfig.tar.gz ~/.dBpoweramp
          This will produce a file named AssetConfig.tar.gz in your home directory.
          Thanks for your feedback.
          • Graham Russell
            • Sep 2010
            • 35
            #35
            Thanks for the new beta. It looks like it has fixed the buffering problem.
            I have paid for the full version on Pi but since rebuilding the Pi and installing the betas I am now running a time bombed version. How do you suggest I incorporate the license to upgrade the latest beta to the released version?
            Graham
              • 43922
              #36
              Extract the beta over the existing to retain registration status.
              • Graham Russell
                • Sep 2010
                • 35
                #37
                I rebuild the Pi with a fresh OS installation and only installed the new betas as you released them. Should I installed the released version then extract the beta over the top?
                  • 43922
                  #38
                  Yes
