Corrupted files after Perfect Tunes scan
  • monsterjazzlick
    • 1764
    Re: Corrupted files after Perfect Tunes scan
    If I have a question regarding this issue then should I post it here? Or would it be better to start a new thread? I only ask because this thread dates back to 2014.
    Many thanks,
    Paul
      • 43915
      Here is fine if relevant to the title.
      • monsterjazzlick
        • 1764
        OK, thanks Spoon. I just wanted to check first simply because the thread is a little dated.
        • monsterjazzlick
          • 1764
          I am currently ripping my 600 x CD collection to FLAC (using 'dBpa').
          Yesterday I experienced an issue of which I have not encountered before. It concerns PerfTunes and 'corrupted files'. I ran a PerfTunes scan (as I do every so often) and it came up with 5 errors.
          The scan took about 3 hours! (instead of the usual 10 mins).
          All of the rogue FLACs (there are 5 of them to date) seem to play fine. All of the rogue files are ONLY on my SD-card (everything seems to be fine on my C-drive). I always rip to my C-drive first, and then transfer to the SD-card afterwards.
          Now I have cleared the cache of PerfTunes and am at this moment running a fresh scan. The trouble is, it says it is going to take: 2 days & 19 hours!
          I have an up-to-date version of PerfTunes. My files are NOT on a network share. I have run 'Test Conversion' for one of the rogue files (and no 'error' messages appeared).
          Please see u/l screenshots & text-file via Drive:
          Many thanks in advance for any kind assistance offered here.
          Paul
          • monsterjazzlick
            • 1764
            ... and all of my CODECs are up-to-date. Cheers.
              • 43915
              #21
              These files it identified, right click >> Convert To >> Test conversion, does dBpoweramp say they are corrupted?
              • monsterjazzlick
                • 1764
                #22
                Hi Spoon,
                I just ran another TEST CONVERTER for you.
                I assume, if there WERE any such 'corruption' of the file, then this/these would be displayed as part of the 'report' after the scan has completed (ie. like a pop-up message)? If so, no such pop-up message appeared in either of the scans:
                However, PerfTunes lists them as being 'corrupted'.
                Many thanks.
                  • 43915
                  #23
                  The rescan detected also as corrupted? try this version of PerfectTUNES:
                  Changes Graphics are cleaner Supports 200 and 300% DPI scalling ID Tag: Option to disable predictive typing Opus Codec Added Download Install over the top of the registered (if offered to uninstall select no) version for continuation of registered status. <now released> Please direct all discussion here:
                  • monsterjazzlick
                    • 1764
                    #24
                    Hi Spoon,
                    I ran a PerfTunes scan last night on just the PC C-drive, and an external-HD (both of which contain identical FLAC files of my ripped CD collection - approx. 130GB). The SD-card (with the previously discussed 'corrupt' files on) was NOT plugged into the PC during the scan. Here are the results (the scan, for the C-Drive and external-HD, took about 3 hours):
                    I am guessing that, because the C-Drive and external-HD (ie. 'C' & 'F') are NOT appearing in the list of circa 3500+ 'corrupt' files that the FLACs on these two storage-devices are OK? I am not sure how/why the SD-card (ie. 'G') has the results for 3500+ files because the SD-card was not even inserted during the scan? Having performed a cache clear, it is the SD-card scan which PerfTunes approximates will take circa 2/3 days to complete.
                    Paul
                    • monsterjazzlick
                      • 1764
                      #25
                      Thanks, I will look into this ...
                      • monsterjazzlick
                        • 1764
                        #26
                        Hi again,
                        Using the above version of PerfTunes for the SD-card FLACs, the scan did not estimate as taking 2/3 days. Instead, it completed the scanning process in the typical time-frame (not sure if this indicates anything?).
                        However, the results were that ALL the files (3500+), on the SD-card, are 'corrupted':
                        Paul
                          • 43915
                          #27
                          And if you use Batch Converter, and convert all 3500 tracks from the SD drive to Test Conversion, no errors are shown at the end?
                          • monsterjazzlick
                            • 1764
                            #28
                            OK, I will try this ...
                            (It says the Test Conversion will take 2 hours ...)
                            • monsterjazzlick
                              • 1764
                              #29
                              Hi again Spoon,
                              The Test Conversion of the SD-card has completed (4,000 files actually!). As far as I can see, there are no 'errors'? Please see screenshots:
                              Hope this helps.
                              Paul
                                • 43915
                                #30
                                Something is stopping PerfectTUNES from reading the SD card, perhaps anti-virus? or security permissions?
