Results 1 to 5 of 5
Thread: Ripping and naming multi cd collections
  1. #1
    Join Date
    Feb 2014
    Hi All,
    I've been working on path and file naming
    [genre]\[album artist][IFCOMP]Various Artists[]\[album][IFMULTI] (Disc [SETLEN]2,48,,[disc][])[]\[IFCOMP][SETLEN]2,48,,[track][]-[artist] - [title][][IF!COMP][SETLEN]2,48,,[track][] - [title][]
    this does almost everything I want....though just shy of perfect.
    currently this gives me
    Pop\Madonna\Immaculate\05 - Holiday
    Pop\Various Artists\Immaculate\05-Madonna - Holiday
    Pop\Various Artists\Immaculate (Disc 01)\05-Madonna - Holiday
    Pop\Madonna\Immaculate (Disc 01)\05 - Holiday
    for multi disc sets though I would like
    Pop\Madonna\Immaculate (Disc 01 of 03)\05 - Holiday
    I've found if I add anything else it disrupts the whole string. Am I hitting some sort of string length limit?
    using latest version of registered software
    insights please
  2. #2
    Join Date
    Apr 2002
    Re: Ripping and naming multi cd collections
    Disrupts the string in the editor? or the final filename when you rip?
  3. #3
    Join Date
    Feb 2014
    hmmm, I went to get an example and this time it worked.
    [genre]\[album artist][IFCOMP]Various Artists[]\[album][IFMULTI] (Disc [SETLEN]2,48,,[disc][][][IFMULTI] of [SETLEN]2,48,,[disc_total][])[]\[IFCOMP][SETLEN]2,48,,[track][]-[artist] - [title][][IF!COMP][SETLEN]2,48,,[track][] - [title][]
    produced the output I am looking for.
    Anthology; The First 30 Years (Disc 01 of 02)
    maybe there was a stray character... well thanks prompting me to try again.
  4. #4
    Join Date
    Feb 2014
    Quote Originally Posted by librarian View Post
    OK I'm noticing that
    [IFMULTI] (Disc 02 of Disc 2)
    is added to album meta data line. right now its an extra step to remove that before I rip...
    I can live with it for now, please add to the "would be nice to fix" list, please
  5. #5
    Join Date
    Sep 2011
    insights please
    I'd suggest you just use a separate profile for multi-disc sets. As you've already discovered, long, complex naming strings are cumbersome and finicky. Breaking it up into profiles for your two or three most common ripping situations is much easier. (You can, of course, make as many profiles as you want, but to address the immediate predicament you describe, I'd at least create a separate one for multi-disc sets.)
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
